Acceleration Cable
Angler
Sticky acceleration pedal. Thought that fulcrum of the pedal itself was giving resistance. Not sure
Can acceleration cable be lubricated ? Does acceleration cable need to be replaced ?
2000 Chev. Silverado 4.3
Just get a can of carb cleaner take off the air intake duct and spray the throttle body butterflies while opening and closing them.
Note don't spray a lot. spray some then put the air intake duct back on and start truck up once it is running smooth turn it off and repeat 3 or 4 times...this should take care of your problem.
There is a TSB on this but it is very involved and should not be done unless you know for sure you under stand how to do every thing it says.
I will post it if you want
Thank You Matt for your help. You were right on the problem. I had no idea that a sticking butterfly would transfer
that much resistance to the cable and then the pedal. When I sprayed the throat big chunks of black carbon went
flying. Now I am motivated to do a more cleaning at the intake and valves. I can see more carbon down the throat.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
