2003 gmc sierra evap problems
jg250
I have a 2003 gmc sierra it has a 5.3 v8 4x4 sle. In the past year the evap light keep on coming off and on. I get a p0455 code. I have changed the gas cap. Recently in the morining when the truck is cold it runs very ruff. Like it gonna stall. Then after it warms up its fine. I am concerned about the major evap leak code that keeps on showing up. does anyboyd know what the problem might be and why it runs very ruff when cold but goes back to normal when warm. Can sombody please help me diagnose or give some suggestions on where to look.
Thanks
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
