130amp to 105amp alternator
My truck came stock with a 130amp. However, they are massively expensive.
Has anyone ever just put in a 105 amp alternator? Im just curious to see how good they run, if they work at all. Alot of the 4.3L V6 Alternators on the Blazer/Jimmy line are 105 amp, and they have the same connector/look as mine (130 amp)
Yes you can do it. I went the reverse by putting a 145A alternator in place of my stock 105A unit. The only change I did was to get a longer belt - all mountings and plugs were identical.
I just re-read your post and was thinking you had a V8. You have a 4.3 with a 130A alternator? That's unusual since it was optional on the V8 models. Still, I suspect that you could swap the unit with out having to make any modifications other than a new belt.
Do you have the electric fans on your truck? If you do you need the 130 Amp alternator to provide the extra current. My 2005 GMC 4.3L has electric fans and has a 130 Amp alternator standard. Those fans move a lot of air and need that extra current to keep the truck cool and to prevent battery drain.
If the MFR put a 130a on thats what is needed dont be cheap you will pay for it in driveability & performance especially if you have a 3:23 axle.
As for the electric fans i have a 130a with GM fans with no problems.
    ballencd
    ballencd
  • Who's Online   4 Members, 1 Anonymous, 595 Guests (See full list)
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
