07 silverado 1500
cerbomark
For sale, below pictured Silverado, Z-71, Lt1, 3500 miles (yes only 3500), extras include 20in GM wheels, GM side steps, GM rear cover and bedliner. It s only going if I am happy with new diesel when it arrives. $32,000/ serious inquries only please. Thank you.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 1 Anonymous, 1,183 Guests (See full list)
