Anyone have a carfax subscription
  • 4 weeks later...
Hi guys I have been away for awhile and I can't start any new threads without replying to a post. I also have a Carfax request. I am looking at a 1996 2-door tahoe with a VIN 3GNEK18R5TG110557. Could someone check this out for me? Reply, PM, or email me at [email protected] whatever is easiest. Thanks a bunch :confused:
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
