What exactly is a torque converter?
drumset5994
OK, i have been confused for years on this.
What exactly is the torque converter and what does it do?
I understand it comes into play with overdrive. I feel 4 gears, then around 45, my RPM's drop as i cruise into Overdrive. I can also feel it if i shift it in 3rd, then let it go through the gears, there's a slight RPM drop as i cruise above 50.
Is this the torque converter at work? Is basically it only work at highway speeds?
Also, what constitutes the torque converter "locking" ...is it where it softly downshifts without downshifting into 3rd? Usually i can feel it downshift going up a hill, but if i drop it from D to 3, it'll shift down harder.
Check out THIS page. That should answer your questions.
The torque converter is ALWAYS at work. From zero mph, to as fast as you can go.
That's what makes you go.
Easiest example of how a T/C works is this.
Take to house fans, point them at each other with one on and the other off, the flow of air represents the flow of fluid from the engine side of a T/C and the fan that is being moved by air flow represents the transmission side of the T/C.
It is pretty simple , and to obtain "Lock up" there is a clutch disk between the blades that is applied to make the engines rotations mechanically connected to the transmissions input shaft .
Stall speeds which T/C are rated with are determined by inner blade angles, to see this with the 2 fans take 1 fan and off set it's angle from the other one and you will notice the free wheeling fan will spin slower meaning it has a greater stall speed then when each fan sat directly in front of each other ..
Good question Drumset5994.
I had an idea of what it did, now at least I know for sure.
Makes it very understandable..how i feel a sudden surge in downshifting without the clunk...the torque converter. Now i now how my S10's tranny was going...it would slip in highest gear till the torque converter would kick in. Sometimes slip very very bad. Makes me wonder if it was the torque converter not working right or the tranny slipping.
The slipping you are talking about was the tranny, a T/C can not on it's own change its stall speed , the blade pitch in side is welded in position .
I can give ya all a simple transmission explanation like i did the T/C if you want to visualize how simply it also works ..
That would be great....thanks!
Well here goes , I have to guess but most if not all here understand how a break caliper works ? Very basic you apply a piston which pushes fluid down a line to a second piston which in turn pushes against the break pads .
A transmission works exactly like a hydraulic break system.
The pump which is driven by the torqe converter acts like your foot on the break pedal,,It produces the pressure the transmission needs to perform breaking actions.
When you place a transmission in a given gear all items not related to that gear are held in place by disk like clutches or bands which look like a belt you where around your waist.
The clutch pack , OR band is applied by a piston just like a caliper piston applies your breaks. When a gear change takes affect what you are feeling is the application of these pistons applying force to bring a moving part to a stop. When a transmission "Slips" what happens is these clutches or bands are not able to hold the rotating parts and as a result you will lose that gear. (This can happen as a result of a bad seal on the piston, a stuck valve or because teh friction material the bands and clutches are coated with has worn off.
It is a tad more complicated in its controls with in the valve body but simple as well in that the pumps pressure increases with speed and as it does springs are compressed moving a valve which "Reroutes" the oil to the next gear's piston. Modern Transmissions use electric sensors which trigger a electrically controlled valve to open or close,,same principle as spring pressure but technically more efficient .
Basically it is a gear set connected and controlled by a hydraulic breaking system ! !
    DaleB
    DaleB
  • Who's Online   3 Members, 1 Anonymous, 1,533 Guests (See full list)
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
    • Yes. You need to check out that thing, and the hub further.
    • Would this be normal or a worn CV Shaft? 51K miles 3.5" lift? Boots are intact and no visible leaks showing. Attached is a the video I took. Thanks     https://youtu.be/ZnW7PPRmjJY?feature=shared
    • If everything checks out at the MAF, then the MAF is BAD, new or not.   You don't need a signal generator to troubleshoot this. PCM needs ALL powers and ALL grounds able to light a halogen headlight bulb - if it can light the bulb bright, then the wiring is good enough to run the PCM.   Best thing you can do for yourself is spend some time here: scannerdanner.com - Check out all his YouTube videos on similar issues. If you decide to subscribe it's the best bang-for-buck ratio in the automotive world, hands-down. He's got TONS of free vids on YouTube, too.
