Replace Fan Clutch When Replacing The Water Pump
I posted this in the small/mid-size forum, but that forum never sees the life this forum does and this is a general maintenance question...
Might be replacing the water pump on the wife's 2000 Blazer (~83k miles). I always remember that whenever you change out the water pump it was a good idea to put in a new fan clutch as well.
Well a new water pump is about $57 (reman for $38), but the fan clutch is $77! Any idea if this is still standard? Don't want to drop another $80 if it's not really required.
Also seem to recall you want to replace the upper radiator hose as well at the same time ($21).
Thanks,
Chris
    hotfish
    hotfish
  • Who's Online   5 Members, 0 Anonymous, 815 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
