Diy Air Intake Tube
anybody make their own custom air intake tube between air filter box and throttle body?
on my 2000 5.3 the rubber grommet on the tb measures around 4" id, it then needs to make a sharp 90deg bend
(can't stick out more then 41/2" or will rub on fan blades). then need around a foot of straight pipe to join into factory rubber bellows. any ideas on what product to use? white pvc, regular exhaust piping?
I would shy away from PVC if I were U but I have seen it done! Its not flexible and if for some reason it shifted enough to get hit by the fan or got brittle or something such as an accident cracked it....pieces may get sucked into the intake?
I've seen it happen on Turbo Diesels and they will mess a turbo pretty bad but its just a RARE possibility Self aspirated gasoline engines! If you could come up with something that when impacted it dents or gives would be better.
I use exhaust tips for my intake tube. Every time I give it some gas, it goes WOOOO-WOOOOOOO!
well i think the only way im going to make something fit will be to remove engine driven fan and clutch
and replace it with electric fans. that will give me about 8 inches of room for the 90 deg bend. reading lots of posts and am leading towards some ls1 car fan kits. i know i have the 28 inch rad and a tranny cooler to worry about, maybe go and check autowreckers on days off.
oh i also have some msd 8.5 super conductor wires coming tomorrow, will post a review vs stock
i installed the msd wires last weekend, and have not noticed a difference in idle smoothness, power or fuel econ.
yet. somewhat disappointed.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
