Xm For Tahoe/delphi Tnr800
I, recently, installed a Delphi TNR800 GPS-Nav-CD-Radio in my Tahoe. Unfortunately, there is no way to listen to a CD and get GP guidance at the same time. A really poor decision on Delphi's part.
Who makes the factory XM satellite for GM? and, is it tough to install the antenna through the roof? I am not interested in a magnetic stick on antenna.
Also, in a Google search, someone mentioned an XM radio that has an iPod plug-in which over-rides the XM when an iPod is plugged in. Does anoyone have any experience with that?
TeamTahoe
NorCal
Have your tired calling the dealer? They might be able to help you out.
No, I haven't tried the dealer. I was hoping someone would provide me with a discount house like Amazon.com so I could get the XM and install it myself.
Prices on other XM systems I've found range from 180 to 350 dollars. I want it to look factory.
Try Sirius?
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
