Does My Truck Need To Relearn Every Time I Fiddle With My Hypertech?
My truck was running great since it's last trip to the dealer and today I decided to fiddle with my Hypertech with not so good results!
I never "uninstall" my hypertech before I go to the dealer and It has been installed it since 04 with no problems. Today I accidentally reprogrammed it back to factory settings and then back to my custom settings. After I reprogrammed it, the truck was pinging a bit and lugging of the line although, It seems to be getting better the more I drove it!
My guess is when I took it the dealer a couple of weeks ago for a "Check engine light" and after the $100. 00 fix, by the way, it ran excellent with even better gas mileage! maybe I erased some updates or something?
Could I have erased anything or does it just need time to relearn or I do I need to take it to the shop and have it checked?
I believe I bought my hypertech in 04, for my GMC 2002, Yukon 4X4.
Any ideas?
KevinM :confused:
K.........I also run a Hypertech 3.
But from reading posts from others with all different PCM tunes its
always better to pull out the tune or swap PCMs.
I am guessing that when a "tuned" GM is hooked up to the Tech 2
machine at the dealer and updates are performed the tune (or some
parameters) are erased or modified.
I am showing a SES light on my 04 (due to a loose gas cap IMO)
so its off to the dealer for warranty service. I will pull out my
tune....just in case !...........geo
Update:
Today, the day after reprogramming my Hypertech, My Yukon is running great! It must have been a relearn and a rather quick one at that!
I'm definitely looking into a mail in order PCM or if I could find a good tuner In the area, that would work as well! (Orange County Ca.)
KevinM :confused:
    bellssn690
    bellssn690
  • Who's Online   5 Members, 1 Anonymous, 857 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
