Anyone Have A Wester's Hot Tune 91
the westers tune i have is actually a 89/91 hot. and by older brother has the same on his truck, a '01 Sierra Denali ECSB 6.0L.
the tune runs on the 6 a lot better than my 5.3, but they still pack a good HP, TQ and mileage hit. the denali runs like a scalded cat now. probably will outrun my short wide 5.3..T_T
but as for pros and cons, the only con that you have to worry about is the PCM relearn. takes about 45 mins to an hour. the truck has to learn the new PCM before it will start.
havent taken his to the dragstrip, but i have done so in mine. stock was ~10.50, with the tune the best i had on a cool night was 9.80. (1/8 mile, not 1/4. lol would love to run that in the 1/4, but ill get a little closer when i get the turbo...)
and westers can also take into account -like most custom tunes- any mods that you have done to your truck. they are a little pricey, but you get a 15% discount when you send your stock PCM back after you get the new one installed.
Thanks, I actually have the 87/91 tune, but was hoping for better bottom end performance and being able to smoke the tires. So now I'm thinking the 91 tune, was wondering how much better that might be?
not sure, but i bet the hot tune is better than the regular 89/91. id say go for the 91 hot tune. but if you dont get the dual tune, you better be able to find 91...
and if you already have a tune from westers, (the 87/91, i assume) its only like ~$75 or so to have him reflash the PCM for the 89/91 hot or even the 91 hot.
go with the hot tune.. i think youll see a big difference..
But I have a "hot tune" the 87/91 one. What can I expect from the straight 91?
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
