Oil Filter
If your using the OLM and good oil the filter works just fine and no larger filter is needed. My 2000 5.3 has 227000mi and is a 4x4 EXT and has been used for a service truck since new hauling a tool trailer all the time. No internal related problems so far using Mobil 1.
buy a filter for a 99-02 5.3L. it is much longer
The PF59 is discontinued.
Use the recommended filter. If you start using different numbered filters JUST 'cause it is bigger. does not mean tuou are using the correct filter. THere are many things, to consider, volume, drain back valve, filter area, burst strength,
I am not 100% sure and am not where I can check right now, but I am pretty sure the thread size changed on these engines, which will not allow the old style PF 59 to be used. Although the PF 59 is gone, there are still other mfgs out there that still make the longer filter for the 99 to 02 models.
On the original poster's question, as others have recommended, I also would suggest the filter that is listed for your truck.
In my opinion the quality of the media is more important that gaining a few sq inches. Wix is our (CARQUEST) supplier and I have used their filters since 1977 and belive they are on of the highest quality mfg's offered. There are other good filters out there but there are also some avail that are simply very poor quality.
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 246 Guests (See full list)
