10% Ethanol
aediaz
If you have bought gas in the last year you are running E10.
That's not true. Not all gasoline sold is E10, and if it is E10, it has to be labeled as such.
Yes, you can run E10. According to your Model year, you should be able to run E85. Many, but not all 2002 5.3 engines were E85 capable. And yes it must be labeled as "Ethanol 10%", which is usually right next to the pump handle.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
