How To Quiet Noisy P/s Pump (growl)
My 2006 YukonXL Denali P/S pump growled very loud so the dealer replaced it at 4000 miles. The replacement started the same issue when a friend recommended sucking out the fluid with an oil extractor and re-filling with Royal Purple MAX EZ Synthetic P/S fluid. I bought the fluid on line and did one extract/refill and the growl was gone literally in 3 minutes. I highly recommend it. :confused:
    flyclt
    flyclt
  • Who's Online   5 Members, 0 Anonymous, 592 Guests (See full list)
