92 Tbi On A 95 Tbi 454?
I've got a sticky/worn throttle shaft on my 95 GMC 454. I've been hunting for a replacement TBI assembly, but haven't had much luck. I did stumble upon a new OEM Delco unit for the 91-92 454's, and am wondering what the differences might be or if I can make it work? The older unit has the IAC and TPS, and what looks like the correct (3) vacuum ports on the front. Is there any significant portion of the TBI that changed in 1993, and maybe up through 1995? Any of you techs know?
Thanks,
Jay
Check the fuel pressure specs for 454ci throught the years and i believe you will find that the 91 or 92 has higher fuel pressure. The regulator in the TB will need to be changed.
