Anyone know of a good brand ABS bed cover? I am looking to put one on my 900 series Silverado soon and there are so many out there that claim to be water-tight but all their reviews say no.
Anyone know of a cover that is MOST water-resistant than the others and is still decently priced?
Thanks guys
Thanks guys
For a hard cover I would get an Undercover. I just don't know if they're out yet for the NBS
Just put an Undercover on my NBS crewcab shortbed. You just need to change out the "fin" tailgate guard to the "classic" style. I had one on a 2000 Sierra and loved it. IMO, the Undercover is the way to go. The new one I just got had a few good improvements over the old one I bought about 4 years ago for my 2000. I would never consider another cover over the Undercover. And NO, I am in no way connected to Undercover, other than being a VERY satisfied customer.
  • 1 month later...
Not sure if you still looking, but I have a GT Classic by Gemtop, and it is pretty darn water tight..
It is painted the same color as my truck, and matches really good... I got it with the truck, so not sure but I think it was ordered that way from Gemtop...
Like I said it is pretty watertight, but does get a little dust in there, but I think that comes from the tailgate and not the cover..
I will try ?? to post a picture, and have a few more if you want them...
Narley
    Sothpaw27
    Sothpaw27
  • Who's Online   4 Members, 0 Anonymous, 825 Guests (See full list)
