Noise When Towing
plinkie
2000 G.M.C. Sierra 5.3 3-73 gears, 110 km. I need some help on this one. When towing with truck cold, no noise at all. Once on the hi way for approx. half hour or more, and I slow down for a city or town, I hear a noise coming from under the dash just below the ashtray and cup holder when accelerating. The noise can not be heard at speeds over 60 kms hour, but when I slow down in a town, you hear the noise when truck is accelerating and switching from 1st, 2nd, and 3rd. Once over 60 km, basically gone. I am towing a 3000 pd boat in 3rd. using t.h. The noise that is coming from behind the firewal??? sounds like someone braking dry leaves or crumpling a newspaper. The noise does not change volume with speed, but does disappear momentarily between shifts. This is a very strange noise, and hard to describe, but doesn't really sound like it is coming from the engine at all. I suspect transmission because of the absence between shifts. but as everything is working well, and I have a large trani cooler installed, I am totally stumped. Please give me your opinion of what could make such a strange noise. Also, you never hear the noise unless towing. Thanks
  • 1 year later...
Did you ever find the source? I have a noise under light throttle while towing that I'm trying to figure out, I'll have to pay better attention to the shift points and see if it goes away during shifts.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
