Where's My Clock Go?
Ok - I swear I didn't touch anything or change any settings but the clock in my 07' NBS Silverado likes to disappear at times. I'll start it up and the clock is gone. Next day, the clock **may** return. See below....
Radio display w/ clock display
Radio display minus clock display
Any guess why this is happening?????
Guest 007FL
Your with and without photos show you using different audio sources (XM vs CD). Any chance the missing clock is always missing when on XM?
  • 3 months later...
Bump....
Anyone else having this issue? Clock display tab disappears...seems to be tied to whether or not there's a CD loaded. I could be listening to any source ... if there's a CD loaded, clock tab disappears. If I pull out the disk, the clock tab will return the next day.
Bizarre indeed. :uhoh:
Guess it's time for the dealer to mess w/ it.
  • 4 months later...
For anyone with the same issue, GM finally put out a TSB in January 08' recognizing this problem. Still no fix tho.
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 224 Guests (See full list)
