Removing Grille Bowtie On Nbs 2007 To Paint
There are no screws that I can tell. Has anyone done this?
Thanks,
dp
I painted mine and it's really simple to take out. First take off the black cover thing with all of the little plastic screws so that you can access it better. Then I took a screwdriver and pinched the two clamps outward and eventually (working very slowly) I losened it and then it just popped right out. Be careful though, I heard if you break one of the clamps it will not fit back in so you'll have to go find another or somehow stick it in there. Hope this will help.
Thanks,
dp
You don't have to remove the plastic screws, I can fit my boney arms in there and I just used my key to push the tabs a little bit and you done.
If you do break the tabs, just PM me I have lots of the bowties.
Thanks,
dp
Thanks! I am about to try it. I will let you know how it goes.
dp
Thanks,
dp
dp
Great advice! Thank you very much!
dp
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
