Which Shocks?
Hey everybody, well it's finally come to the time I need new shocks. Mine are SHOT, if you push my truck in shakes for 2 days. At the same time I want to raise the front up. My questions are these
1-how much does raising the front affect the ride?
I like the smooth ride of the rado now but, will it lose that?
2- Which are good shocks to get for the truck? I've heard everthing from trailblazers ssv, to OEM which I was told were great shocks to get? I don't do alot of offroading but I do haul construction chit.
What do ya think?
Raising the front will make it stiffer, if you dont like a stiff ride you wont like cranked Ts.
Get some bilstein shocks they ride really good and are decently priced.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,193 Guests (See full list)
