Installing Old Style Antenna On 07 Denali
tommbo
I have a 2007 Denali and my fm radio reception stinks! They use a new style antenna mounted in the rear window. My question is..can I install the old style mast antenna without drilling the fender? Also what is the GM part number for this mast antenna? Thanx for your help...
You should have just as good reception from the window antenna. You may want to go to the dealer and see what the problem is.
Subject: Radio - Poor AM and FM Reception (Inspect and Fully Seat Connector) #06-08-44-033A - (05/18/2007)
Models: 2007 Cadillac Escalade Models
2007 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2007 GMC Sierra, Yukon Models
This bulletin is being revised to clarify the location of connector C213 in step 3 of the Correction procedure. Please discard Corporate Bulletin Number 06-08-44-033 (Section 08 -- Body & Accessories).
Condition
Some customers may comment that the radio has poor AM and FM reception.
Cause
The radio antenna coax cable may not be fully seated at connector C213.
Correction
Remove the driver and passenger windshield pillar garnish molding (A-pillar trim) and disconnect the wiring harness.
Remove the instrument panel upper trim panel and disconnect the electrical connections.
Remove the foam tape surrounding the radio coax cable electrical connector C213. Connector C213 is located under the top left side of the instrument panel upper trim panel on all vehicles except the Cadillac Escalade EXT and the Chevrolet Avalanche. Connector C213 is located under the top right side of the instrument panel upper trim panel on the Cadillac Escalade EXT and the Chevrolet Avalanche.
Inspect connector C213 and manipulate coax as needed to ensure that the connector is fully seated (The above graphic shows the connector properly seated).
Install foam tape around connector C213.
If re-securing the connector does not correct the condition, refer to SI for further diagnosis and repair.
Install the instrument panel upper trim panel and electrical connections.
Install the driver's and passenger's windshield pillar garnish moldings (A pillar trim) and electrical connectors.
Subject: Poor radio reception - keywords antenna AM FM mast tool #PIT3839 - (01/10/2006)
Models: 2001-2002 Chevrolet Old Body Style Trucks and Utilities
2001 -2002 GMC Old Body Style Trucks and Utilities
2002-2006 Cadillac Escalade Models
2001-2006 Chevrolet Avalanche, Tahoe, Suburban
2001-2006 GMC Yukon Models
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Some customers may complain about poor radio reception on Full Size Trucks and Utilities. This concern may be related to a loose radio antenna mast .
Recommendation/Instructions:
In an effort to allow the dealer and subsequently the customer to properly tighten their radio antenna mast to the base, a new orange or black plastic "wrench" will be shipped attached to the antenna mast starting mid-April, 2001.Dealers should utilize this tool to properly attached the mast to the base and then remove the plastic orange or black wrench and place it in the glove box for the owner's use later.
Note: The only way to order a replacement wrench is to order a new antenna mast assembly.
Condition
Cause
Correction
Thanx so much I will be taking apart my denali in the morning!! Is the upper trim panel the top part of the dashboard or the snap in trim around the radio?
Condition
Cause
Correction
Since your vehicle is under warrenty i would suggest you take it in to the dealer. If you break anything YOU will have to pay for it if they do they pay for it. Also if you fix it there is no tracking of the problem for GM to know and correct the problems.
Condition
Cause
Correction
Thanx Chevytech007...that was it, I now have great reception!!!!
  • 1 month later...
Condition
Cause
Correction
hey chevtech..I still have this problem. I thought I fixed it but no. The dealer changed the radio,antenna(whole window),and antenna module. I still have bad reception. Is there any way you can send me the picture of the connector in the bulletin? Thanx...
    JustusTX
    JustusTX
  • Who's Online   4 Members, 0 Anonymous, 643 Guests (See full list)
