07 Nnbs 3" Bl/2.5" Front Level Kit/wheels/tires
After a much anticipated, very long wait, the 3" bodylift and other various mods have finally been installed. :)
I was away for a few days and upon my return today went straight to the shop who did the installs while I was away. Of course it's been raining hard all day long and during the photos taken, so excuse the shoddy pictures.
New mods installed are as follows:
Custom 17" GMC Black Powdercoated Stock Wheels
295/70/17 Cooper Discoverer STT's
3" Performance Accesories Body Lift
2.5" Front End Leveling Kit
The shots were taken with the 4 stock wheels and tires still in the bed, so the rear may be lower then if it were empty.
Pictures don't really do the truck justice. I'm really happy with the overall look. Just have to get used to the height, truck looks quite massive in person. I will get better quality pictures when time permits, I hope to send beter pics for consideration in the calendar. I plan on adding LineX coated NFab bars, painting the rear bumper as well as a few other extras.
I'm lovin the blacked out look. Very cool. Those wheels are pretty sharp too, a good twist to an already sharp wheel.
Looks really good. When you take more pics, can you get a close up of one of the wheels? BTW, thanks for posting like you said you would. :)
Looks good. This is exactly what I'll be doing only I'll be using Procomp 1079 wheels. If you don't mind me asking, what did the installation of the BL cost you? I'm pretty confident I could do it myself, but time is always an issue.
BTW, have any shots from the rear? That's always a good angle for tires IMO.
:thumbs: Looking pretty sick all you need to do to finish it off is Tint the windows and tail lights then paint the rear bumper and you'll be ready for you stealth manuvers :confused: .
Looking GOOD! Pull those frame tags of of each side and you'll be ALL blacked out.
Daddy
P.S. What Calendar?
Oops..that's my bad. I copy and pasted my post on fullsizechevy.com. They put out a calendar each year featuring members' trucks.
Thanks for the positive comments everyone.
Looks really good. When you take more pics, can you get a close up of one of the wheels? BTW, thanks for posting like you said you would. :thumbs:
Thanks krww06
Below are close-ups of the wheel off the truck, and one before powdercoating. Sanded down the center cap since it read 'GMC', and painted them with primer, black basecoat and clearcoat to match the powdercoating.
I will take better shots on a better day when the truck is cleaned up, and include a close-up shot of the tire/wheel set-up.
I brought the truck to a local shop who happens to have a super-clean shop, and was 2 miles from me, both meant a lot to me.
They charged me hourly for everything and I got whacked pretty good. 3" BL, 2.5" Leveling Kit, very carefully mount and balance the tires on the powdercoated rims, then finally a front and rear wheel alignment. Total hours spent 14+ at $88/hr, do the math, it wasn't cheap.
I know they were ultra careful with everything, and even used a nylon lined socket for the black lugnuts.
Depending on where you are geographically, I'm sure you could get a much better install price.
Looks really good. When you take more pics, can you get a close up of one of the wheels? BTW, thanks for posting like you said you would. :tear:
Thanks krww06
Awesome! :thumbs: I wonder how those would look on my white truck????????? :confused:
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
