07 Nbs Nerf Bars (need Pics)
The wife and I want to put some nerf bars on her truck. I like the round, she thinks she likes the oval. She would really like to see a picture of both styles on the truck.
Does anyone have a picture of the completly round ones and a picture of the oval ones that I could show her. Thanks.
Take a look at the NFab 2 steps before you decide.
I just posted pics of them on my 07 NNBS Silverado. I had them LineX'd cause every single step bar straight from the factory I ever saw rusts after a year or two, even the stainless ones. Now they're bullet proof. Or you could get them either painted or powdercoated to match your truck color.
http://www.gm-trucks.com/forums/index.php?...c=67224&hl=
  • 3 weeks later...
Not sure if you are still looking for pics of the 6" ovals, but me and my wife like them. The 6" ovals make it very easy to get in and out the truck because you don't have to guess where the pad is to step up on.
FYI, the factory 6" oval nerfs are also available in black............I just ordered them through GMPartsDirect in black. I didn't want the chrome ones to stick out too much on a black truck.
Does anyone have a list of the GM part #s for the nerf bars? Looking for chrome here.
TIA!
Clilck on this:
http://www.gmaccessorieszone.com/index.php...x_gmshopb2b_pi1[year]=2008&tx_gmshopb2b_pi1[division_name]=GMC&tx_gmshopb2b_pi1[vehicle_name]=Sierra
Then once your on the accessories page for your truck, make sure that you're on the '07 tab, then when you see the factory nerfs, the part number comes up. This is GM's accessory site. I validated these numbers on GMPartsDirect, and that what I ordered for about a buck and a half
less, no tax, a little shipping, done!
    Gkistler
    Gkistler
  • Who's Online   4 Members, 0 Anonymous, 926 Guests (See full list)
