95-98 Door Lights
How do I replace the light bulbs in my doors? Does the piece just pry out or do I need to remove the entire door panel?
Okay, I found out after prying off one of the door panels that all you have to really do is pry at the top and bottom of the white piece at the inside edge of the red reflector. Make sure you are prying at the white piece behind the red reflector and not the reflector itself!
Thanks anyways though!
    zibzer2
    zibzer2
  • Who's Online   5 Members, 1 Anonymous, 784 Guests (See full list)
