4" lift
Big Boy
Thinking about a 4" Rancho lift or a 3" body lift.  Been looking around for pics of a truck with just the 4" lift.  Are there some here I'm just not seeing?
Is there someone out there besides Rancho that does a 4" lift.  Can't go higher cause the little woman likes to drive it too and she has to work to get in already. (she's a petite 5'3")
Thanks
I've got a bodylift on my truck.  If you look around the picture post forum you'll find tons of pics of it, or just go to my site for some pics http://www.chevy4x4trucks.com
I think trailmaster makes a 4" lift as well, but if you want to go 4" rancho is the lift to get IMO.
With my bodylift I can jump in and out no problem (I'm 6'4")  However my little sister who's 10 has some problems getting in since I got the lift, especially if she's trying to get in the back seat.
Saw your truck pics - Very nice!
Just curious about the suspension lift.  I guess looks would be very similar although I heard that someone who put on the 4" from Rancho actually got 5.5" from it.
Yeah, you actually get close to 6" from the rancho lift at the factory T-Bar settings from what I've heard.  IMO a suspension lift is going to be more lift than you'd want and would keep the wife out of your truck (unless that's your goal :thumbs: )
body lifts are cheap, but if youve got the cash, put on the rancho 4".  it does indeed come out to about a 5.5".  and looks and rides great.  my neighbor has one on his 2000 ext cab z71.  i can take some pics of it and post them on here if you'd like to see what his looks like, he has 33s w/ 16x10 welds on it.  looks so good!
Just my opinion, but I would go with the TrailMaster 4" lift.  TrailMaster generally tends to use better materials in their applications and their springs rates are usually a little higher.  The body lift is fine so long as your not going to be doing a lot of off roading.
You can  check out my pics, I have both the body lift AND the Rancho 4".  I love the Rancho.  I HATE the body lift.  It looks good, but there are so many things that I feel limited by it, for example the amount of weight you can put in your bed.  Since the bed is no longer sitting directly on the frame, if the load is too heavy, it could bend the bed (not likely, but a possibility).  Also, if you want a grille guard, that is a grille GUARD, not just for looks, then you have to have custom brackets made to attach the guard, which means you lose a lot of the strength of the grille guard.  Also, your tow hooks have to come off, unless you want to drill 2 more holes and mount you tow hooks to those.  Then, there's the whole seeing of the frame from the side view.  I have some nerf bars that block that view, but still it bothers some people.
Well, feel free to take a look at my pics, and good luck to ya.
I have been told by several people that Rancho is the way to go if you want a suspension lift.  Rancho welds the main frame together for strength.  On the other hand, I have also been told that you can't reverse a Rancho lift on GM trucks.  When my p/u comes in, I plan to put a Rancho lift on it to reach the 5th wheel.  I convinced the wife that it is much better to lift the truck than lower the camper.
    whenindoubtuseahammer
  • Who's Online   0 Members, 0 Anonymous, 271 Guests (See full list)
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
