The 305 Challenge
The 305 challenge
66 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
What size wheels? Someone correct me, but regardless you'll have to trim/raise something. I am thinking they will fit with a serious T-bar crank and some trimming as long as your wheels allow it. It is amazing how tires "fit" different with different sized wheels.
16" wheels, and i BELIEVE the rims are 8 wide
The wheels on the picture? Looks like you have 265s or 285s now? The only thing that may keep you from 305's is the chrome part on the front bumper. You can trim everything else if needed, but its hard to get around steel. Mine pictured has 16x8 wheels with 285s and they barely clear the front bumper now when steering. I only turned my bars a couple of turns, but I think you'll need more than just that. The easiest and cheapest may be to just get an aftermarket bumper rather than messing with the suspension and ride quality.
Alternatively I have heard that you can loosen the bumper bolts and slide it forward a bit.
Thanks!
The tires on there right now are 265/75.
Not getting a ton of voting activity on this poll are we? :flag:
Not trying to bust ya bubble, but its been discussed a hundred times already, do a search.
I really don't see what the big deal is. That is what a forum is. A discussion. I'm sure you have had the same basic conversation with several people. His specific application may differ from someone elses. IMO if you just don't want to be bothered by reposts, ignore them and move on. You don't have to read the post, nor do you have to reply. Sorry for the rant Sean.
Exactly. Couldn't have said it any better.
Trim and crank. crank alot it might just be worth it to get a leveling kit. I did fit 315's on my half ton with new keys and cranking the t-bars. However its an older body style so it doesnt help out to much but the tires were on a 16x8 rim without to much bulging so you should be ok on rim width.
***Thread jack alert***
Ivan, how loud is your exhaust, is it loud just for the sake of being loud, or does it have a nice rich tone to it? I'm asking because I'm looking into a truck similar to yours, and it would help if I knew what to expect after the exhaust mod.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
