How Do You Clean A Chamois ?
I just stick mine in a bucket of dishwashing detergent and water. Depending upon what I am using in the house to wash dishes it will change. I wash mine about once a year. I wake up early one morning, stick it in the bucket, and let it sit during the day, kind of adgitating it throughout the day. Never got streaks out, but was more worried about getting trapped dirt out than my chamois looking nice.
On another note, your truck looks nice in your sig pic. I like the bowtie.
thanks, I appreciate that
I really didn't want the hood deflector on it, but the paint is so thin that every time even the smallest rock comes within 10 feet of it, it will chip down to the primer. So I had to put one on, it has kind of grown on me though.
The black bowtie is courtesy of Krylon and a Scotchbrite pad!
I don't use chamois anymore, I use the Absorber. They get black streaks every once in a while, I just toss them in the washer with liquid detergent, then put them wet back in thier container.
I stopped using a leather Chamois year' ago.The Absorber like Gregg said is what I've been using for about 10 year's.Work's way better and alot easier to take care of.
Same here on the Absorber. I hate to admit it, but I bought mine in 1978 and I am still using it. I have not counted how many times I have used this thing but it would have to be in the thousands and it works today just like it did when I bought it. I have never washed it with soap, just warm water every now and then.
Props to the Absorber I just used mine for the first time on Saturday and was amazed on how well it works, I'll never use anything but that to dry off my trucks from now on. As for cleaning your natural chamois I just fill up a sink with hot water and pour some Tide in there with it let it soak for a while then make sure your rinse out all the soap. Even cleaners made specifically for chamois wont get the black marks but it will remove little pieces of debreis
  • 1 month later...
Throw it in the trash. They trap dirt and will scratch the shiat out of your paint.
Waffle Weave MF drying towels are much better.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
