2500 Brake Job
Just had my brakes redone after experiencing a noticeable loss of stopping power. This was a major concern, considering that I pull a 7500# fifth wheel trailer.
Told the tech about the problem and also mentioned that the brake pedal would momentarily push back when I first applied the brakes. He informed me that this was a classic symptom of a bad power brake unit. This was news to me and also the first time I've a PB unit go bad.
After new rotors, pads and power unit, the braking performance is awesome!
    bellssn690
    bellssn690
  • Who's Online   6 Members, 0 Anonymous, 579 Guests (See full list)
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
