Gm Service Bulletin For Nbs Trailer Wiring
Today I got a hard copy of the GM Service bulletins for trailer wiring on the new body style.
They are:
Wiring for adding a brake controller
Wiring to add and aftermarket controller for trucks with the factory controller
Adding the factory Integrated Controller
Auxillary power to 7-way trailer connector
I can scan these documents in as PDF, but have no place to host them, as they are around 1mb each.
Does the forum have hosting available?
OK, after scanning in the docs, only the Installation Aftermarket Controller instructions were over 1MB. Here are the other 3.
GM_Bulletin_Adding_ITBC_as_dealer_option.pdf
GM_Bulletin_Trailer_Auxillary_Power.pdf
GM_Bulletin_Replace_ITBC_with_aftermarket.pdf
Ok, I rescanned the "big" file at a lower DPI, the pictures suck, but the instructions are good.
And in case anyone is wondering the files are a page short because I didn't scan the last blank pages I was given.
GM_Service_Bulletin_Wiring_Brake_Controller__small_.pdf
SinisterSS' pictures are way better anyway. Just thought folks would like to see the GM documents.
  • 3 weeks later...
Thanks for posting the service bulletins! My question is in reference to a 2004 Denali that I recently got and hooking up a prodigy brake controller. The truck is supposed to be factory wired for towing - does that include the brake controller wiring (and not just lights)? I have the adapter harness that plugs into the rear of my prodigy brake controller - the other end is a GM 3015 plug - which I'm assuming mates to the truck somewhere under the dash. However, I have not been able to find the mating connector. Should there be one and if so where specifically should I look? If not is there some other truck wiring harness that I need to wire in so I can connect to my brake controller adapter harness? From the service bulletin starting in 2007 there is no longer a pigtail connector harness plug, although there are still pigtail wires under the dash that can be spliced. That would lead me to believe my Denali (being 2004) has a harness w/ plug - I just haven't been able to locate it. Please advise & thanks in advance for any info. you have.
I'm using the 30amp connection for a 100 watt two way radio in the cab" dont need brake controller I have surge brakes, and Im using the 40amp connection as a charge terminal for my aux battery and its also connected to the 7 wire plug in the back of the truck , I can pull the 40 amp fuse and run an small inverter or camper power off the 7 wire plug in the back, will not run down my starting battery you must put another fuse between the trailer terminal and the wire to the plug though otherwise if you risk frying the wire when over loaded
clearly the 5 page document has everything you need to know see pag 5 item 8.4 thats what I meant by fusing if you put a second battery, otherwise risk frying the harness all the way to the back of the truck$$ I grounded my 2nd battery and ran pos+ wire to the 40amp terminal from there I added a inline 40amp fuse to the trailer connector. now the only problem is if you draw 30-40 amps off that for an extended time you will drain both batteries. I just pull the 40 amp fuse under the plastic cover.
other uses for the brake controller terminal " if you dont need it for its intended use" is a audio power amp up to 30amps, just tap the wire under the dash and run it under the carpet to rear seat where your amp is. Don't forget to hook up the 30amp teminal LAST under the hood
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 713 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
