99 K1500 Misifre/stumble
cjauto
Recently purchased this truck from a friend w/ couple of problems. '99 K1500 Xcab SB 5.7L Auto. The truck has had in the last 6-8 months a fuel pump, plugs, wires, couple O2 sensors, vent solenoid for fuel evap, all the common stuff. Intermittantly I've been having some type of stumble/misfire problem. It happens cold or warm, no given time. When the problem is happening it will still idle fine. As soon as a touch the gas and at any rpm it will mis. It has seemed to happen mostly around a 1/4 tank or less. If the truck is shut off it may or may not reoccur. It has never tripped the SES light. The only code i've read has been 172 (rich bank 1). Plugs don't look bad. I've read other posts saying possible plugged cats, is that possible? Where should I look first? This is driving me crazy.
welcome to the misfire and I dont know how to fix it club. I have the same problem right now and If you look down a few post at 97 5.0 p0302 and p0300 codes post he is have the same problem I have been told and have tried a bunch of different things with no luck so far. I have been told intake gaskets injectors(which I replaced) egr valve , fuel pressure regulator, distributor, and thats about all i havent tried yet. So good luck and if you find the prblem please post it on here. and i will do the same .
I'm in the stumble club too, Welcome :chevy: . Except mine stumbles all the time, kind of getting used to the rocking boat problem :cheers: .
Next time it does it unplug the egr valve vacuum hose connected to the egr valve and let me know if it still does it. I don't have an answer for you, but am real interested in the results.
well I blocked off my egr valve today and I think it cured the problem I have a check engine light of course but its from the egr being blocked and not reading anything. I took it off and the spring is real weak Is it suppose to be like that? anyway going to leave it blocked off for a few days and see it I can get it to do it.
I'm not exactly sure about your truck, but on mine if I just unhook the vacuum line from the egr valve and just push it aside (make sure it's far enough away from the valve or it could still operate the valve, doesn't take much suction) it runs ok and doesn't light up the check engine light in the dash, not good for the environment or gas mileage, but it does stop the stumbling :cheers: , if you figure out the cure please share.
well, i'm glad i'm not the only one with this problem. smoebody has to figure it out. I did learn something yesterday. I was miss informed of the tune-up. It still had fact orig plugs, wires, cap and rotor at 133k miles. I changed them, but the problem is still there. While changing the plugs I noticed that #2 and #3 were fouled (not wet but carbon). I thought this might be some of the prob but no luck. If its misfiring why doesn't it trip a code or light? It seems to present itself more when I get done to about 1/4 tank. Fuel related? I'm probably take a look at some more today. hopefully something will jump out at me. thanks for the egr info i'll try that too.
I'm not exactly sure about your truck, but on mine if I just unhook the vacuum line from the egr valve and just push it aside (make sure it's far enough away from the valve or it could still operate the valve, doesn't take much suction) it runs ok and doesn't light up the check engine light in the dash, not good for the environment or gas mileage, but it does stop the stumbling :devil: , if you figure out the cure please share.
My egr is operated electronically. so if you unplug your egr vacuum line and it cures it I am thinking that its egr related have you taken your egr off and see if it stuck either open or closed. or maybe the spring is weak and it just comes on to soon and gives to much air. which I think would cause a lean condition and make it misfire.
cjauto Posted Today, 09:17 AM
My truck does the misfire thing and it will sometimes set a light and sometimes not. Try unpluging the egr valve and see if you can get it to stumble. Let us know what you find out.
I had the exact same problem on my old 88 silverado awhile back and eventually replaced the EGR valve. The spring was stuck. Id bet money that is the problems for most of you
Well I've replaced a ton of stuff, you can look at my post on this page called "Still Stumbling" with a green smiley icon.
The one thing that puzzles me is that I noticed that the egr solenoid will activate at about 1500 -2000 RPM's for just a few seconds when you hit the gas a little fast. If I slowly rev it up it won't do it, and if I rev it really fast you will feel a small slight stumble as it passes the above mentioned RPM zone.
I found this out by unplugging the vacuum line at the egr, put my finger over the end and reved the engine from within the engine bay (better to have someone rev it for you!) Sure enough as I hit this RPM zone the line had suction. Below the zone, no suction. Above the zone, no suction.
Has anyone changed any of these parts and still had the same problem after; ignition control module inside the distributor, Electronic spark control module, fuel injectors, fuel injector pressure regulator, oil pressure switch, ignition coil, fuel pump, IAC (idle air control switch) or the catalytic converter?????? Just wondering, so I don't have to waste anymore money. Just trying to narrow this down to save us all some time and money, not to mention our sanity or what's left of it :devil:
well I have brand new catalyic converters on the truck and I replaced the fuel injector and just before i got the truck supposeally the guy replaced the fuel pump. so that elimanates those things. I am still driving my truck with the egr unplugged and I havent had it do it yet....
I'm moving in the direction that this is some kind of electrical problem, maybe the ecm, or something not being grounded right or a bad switch that I haven't changed yet, like the expensive ones!
I say electrical because my egr system is brand new, the connections have been cleaned, but yet it something is still telling the egr solenoid to open up around 1000-2000 RPM's.
I'm leaning towards the ecm, because this controls the egr solenoid on my truck, but also it could be something else reporting back to the ecm that the engine is at a certain temperature or speed, then the ecm opens the egr.
Anyone change the transmission temperature switch, maybe that is telling the ecm that it is going faster than it really is?
Not sure if this is the real problem, but it sounds possible in theory :devil: .
If anyone has changed any of these items I just listed or the ones above please list it so we can eliminate that part as a source of the problem.
Noticed over the last couple of days that this problem never seems to happen in the morning on my way to work(only a couple miles though). It seems to happen more often when the motor gets to temp. It only runs around 165 so I'm guessing someone has changed the thermo. Probably when they added the trans cooler. I've been thinking about buying a programmer to make it easier to retreive codes. I've been going to a friends repair shop. Can anyone recommend which seems to be best? Also, how would changing the software effect this stumble problem?
A year ago I had my truck in for some work and asked them to take a look at a similiar problem to what you guys are descibing. When I started my truck in the morning it would sometimes idle rough, with or without the check engine light on. One time I was able to get it to Auto-Zone to read the OBD code. Multiple misfire. It would go away after it warmed up and restarted.
Anyway, while the truck was in (at the dealer) for other work I had them check this as well. They ran a diagnostic and swapped the plugs around. The problem followed the plugs (thank god, as else I was looking at computer problems). They asked me if I wanted them to replace the plugs, I said no, figured I'd do it myself. When I got the truck back the problem had gone away and hasn't returned.
This happened at roughly 40k and my truck now has 78k on it, so whatever they did worked. I didn't pay for new plugs, so to my knowledge they are still original or only a few were replaced. If I remember correctly I had two misfires (two seperate cylinders).
:devil:
mine had the plug change 6-8 months ago. I just changed them again the other day cause I saw #2&3 were fouled but not bad. its NOT tripping any misfire codes, which is weird. I can't be sure but my prob almost seems electrical sensor or something. thanks for the input though
:devil:
did full tune up recently, gapped the plugs myself, sure wish that was my problem.
My stumble issue actually starts a few minutes after the truck is started, i would say about 5-10 minutes later, after the truck warms up a little, doesn't do it if it is cold.
Might change out the ignition control module in the distributor, not too expensive and I know no way of testing this thing, but i do know that if these things overheat they will destroy themselves and when I cleaned up the distributor i noticed that there was no silicone grease under the unit like there would have been when it was new and a piece of the connetor plastic was a little broke too.
Hell i've changed just about everything else mind as well spend some more money i don't have on a part that won't change anything :devil:
I'll post back with the results. Wish me luck :bs:
    250.3k
    chfkief
    chfkief
  • Who's Online   2 Members, 0 Anonymous, 1,555 Guests (See full list)
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
