05' 1500 Won't Go Into Park
I serviced the auto trans on my 05' Z71 1500 4x4 on Saturday, since then it is a fight to get it into park. No sliping of the trans when drving, and it goes up to the (P) on the column but rolls back or forward, not locking in. I've checked fluid three times and it's full. I'm positive the filter popped in like needed into the trans body. No leaks. And no idea what to try next to fix this.
For anyone that has done one of these it's a bear to get the trans pan off due to the shifter cable being atteched to a bracket that blocks the back to bolts on the drivers side, to get them out and mainly to drop the pan I had to pry with a screw driver the bracket out of the way. When finshed it looked like it was back in line, I checked it again tonight, pulled on it the oppisite way trying anything at this point and it did not help. Could I have "streched: the shifter cable somehow? And if so would it only affect the truck going into Park? When parked angled up hill today it went right in?
Any ideas on fixing this?
Thoughts?
Thanks
Thoughts?
Thanks
When you shift into park (as indicated) all that means is that the shifter is in park. Your problem is at the other end of the assembly. My guess is that you bent the bracket for the shifter or somehow repositioned it when you put it back. Either way... fix that bracket and you fix your problem. It doesn't have to be off by much at all.
I have read this time and time again of people bending the bracket instead of removing it. There are only 2 torx bolts holding it in place. I think the last time I droped my trans pan I used a 1/4 ratchet and the correct torx socket and it took all of 5 minites to remove the bracket. And you won't have a problem.
Have a good one,
Don
Thoughts?
Thanks
I've attempted to "bend" it back towards the pan with no change, and it looks like it's dead on straight. Would you suggest going to the dealer and getting a new brakect under the assumption that it's not holding the cable perfectly straight? Or am I just as good to pay the dealer to fix this. I've got to get this correct soon, I'm parked at work on a hill in what feels like nuteral with the e-brake to the floor.
Thanks
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 349 Guests (See full list)
