Just A Couple Things
alpaulcan
The Onstar in my NBS 07 ltz 1500 extended cab quit working as well as the phone. Neither the buttons on the steering wheel or on the mirror are working(for the phone or Onstar, radio controlls are fine). I brought the truck in on thursday and it took them the better part of the day to figure out that it was the VCM or onstar module. The sevice advisor said they had to order a part and it would take 7-10 days and they would phone me when it came in. I picked up the truck the next day and when I tried to start the truck I found the battery was dead. The sevice advisor said it was due to the troubleshooting(they had the key in the on position for an extended period of time)and they boosted it and it was fine. When the service advisor found out about the dead battery she checked for a battery rundown recall or TSB and found that there was indeed one. Don't the service advisors run the vin number of the truck and check for those things as soon as the truck comes in ? Or is this something I have to request ? When I picked up the truck I thought it would be a week or so before I was back at the dealership but when I got home there was a voicemail from the dealership saying I had to come in so they could get a part number from the module. I realize things happen and I'm not upset, just a little disappointed at the level of service from this dealership. Also when I got the truck back the dash was covered in dirty fingerprints again not a big deal I guess mabey I expect to much. Is my Onstar problem a common one ?
The failure with the VCIM is not common. And yes, the service advisor should have run your VIN with the Vehicle Inquiry System as soon as the vehciel is checked in at the service drive to see if there any open campaigns such as the 07007 battery rundown/RKE update.
Exactly right. The OnStar VCIMs not only have a GM part number, but the dealer also needs to read the ESN off the side of the module itself and relay that to the company that will send them a new one, as it does not come from a GM part warehouse. In most cases the GM 8 digit part number for the VCIM can be obtained by simply plugging in the scanner and requesting it from the module. But there's no way to get the ESN without physically removing the VCIM from the vehicle(which is kinda a pain in the ass on the trucks and utilities).
i just wonder how they let it leave without getting the numbers, they shoud know that... it may not be a common problem but im sure they have done plenty enough of them to know that...
    • This is exactly the reason our EV has consumed so much of my driving. I don't want to fire up a cold diesel or gas engine just to drive 2 miles up to the store. It's arguably terrible for an engine. If I'm not driving at least 10 miles and don't need to do truck things, the truck stays parked.   Enter the EV. It's immediately heating or cooling the cabin as needed (heat pump). An engine doesn't need to warm up or be driven gently. I can tear off in it with ZERO guilt. Move the car 1/4 mile from store to store and not think "gee, I'm short-cycling a lukewarm engine".   It doesn't idle in a drive-through. Doesn't idle at stop lights. (OK, neither would the diesel, if I let stop-start have its way, but I don't).   Even moving it out of the garage to wash it... HA! It doesn't need to be started just to move 40 feet. I have cars that I will actually put in neutral and push (no start) in/out of the garage or shop if they absolutely HAVE to be moved. My nice Camaros.
    • Some trailer plugs don't work. This one worked for me. Been using it for two years no issues. Amazon.com: Reese Trailer Plug Adapter, 7-Way Male Plug to 7-Way Female Plug, LED Lamp Out By-Pass, Plastic, Black, Each : Automotive
    • Great video. I almost want to reserve one now.
    • I traced the atf cooling system in my 1500 and it comes out of the transmission, into the bar/plate liquid/liquid heat exchanger, as stated above.  Then it crosses over to the external thermostat/bypass and then  to the aux cooler in front of the main radiator.  Hence, on this routing, the PPE thermostat bypass eliminator is an $85 piece of bling that does nothing for reducing atf temps on this truck.  I think I'll temporarily clamp a needle nose vise grip on the coolant feed hose to the bar/plate cooler and see how much the atf temp drops.  With the use of ULV trans fluid, I'm not convinced running the trans cooler than OEM spec is going to be detrimental to the life of the transmission.    I found this interesting on the Dana/Long site stating that they make transmission cooling/heating bar plate heat exchangers.  I worked with Dana/Long on a few projects when I was at the gas powered fun factory. https://www.dana.co.jp/downloads/PTG/Long/Dana_TOC_SpecSht.pdf  Bar plate heat exchangers are just a stack of stamped parallel path fluid channels, assembled and vacuum furnace brazed to make the final assembly.  Want more cooling/heating, just stack more plates until you run out of package space.   Anyway, thanks for the info, much appreciated.
    • I have thought an EV might have some practical value in extending the life of the ICE members of ones fleet. Now....I'm convinced of it. I've been letting my better half access Raven (Mitsubishi Mirage) for her needs while Dizzy has been in the shop. Being the fuel freak I am and given the fact Raven is capable of over 60 mpg in clean air on a warm day I was taken back by the wife's ability to take a car that had used a half a tank of gas that to that point had returned a value of 57 mpg and return in with a decimating 51 mpg for that same tank in that same day in a 15 mile round trip of short hop errands and a stop in the drive through at Micky D's.  😱   Trust me on this. It would take the remainder of that tank driven on the highway to return that tank to just 54 mpg. This is not a Mitsubishi issue. This is an ICE issue that is magnified in vehicles capable of such high fuel economy values. On a percentage basis your 1500 does the same thing. Short hopping an ICE consumes a good deal more fuel and in doing so provides zero additional useable outputs. That entire volume of fuel is wasted in diluting the cylinder walls oil films, creating crankcase moisture and acid content and the resultant wear.    Enter the SLATE. All of that is avoided and the ICE's advantage in range and made useful at reduced wear for your ICE!   Kind'a cool.
