Windshield Weatherstrip Rattle
I was reading a previuos post that mentioned windshield weatherstrip rattle. I have a 2004 tahoe and i hear a rattle coming from the roof at about 60 mph- how do you physically check to see if actually this is the noise?
Do you have a bug deflector on your hood?
no bug shield- the noise is coming from the drivers side front roof area
The reason I asked is that a lot of people have the issue of turbulence from a bug shield.
If you think it is a molding making noise try taping it down with masking tape and going on a test run. Pull portions of the tape off until you isolate the area that is rattling. You can use urethane to seal it back down if it turns out to be the molding.
If not I guess I just wasted your time. :rolleyes:
Roof rack maybe?
Take duct tape and cover the top & sides from the glass to the paint. One strip will do it. Thake vehicle for a ride and check it out.
Here is some information that might be of help, I never heard of this until today (GM has alot of bulletins on our trucks):
Subject:Tiny Rattle Noise From Roof At Highway Speeds - keywords body bow canning headliner metal sheet speed tin wind #PIT3067C - (11/08/2006)
Models:2003-2007 Chevrolet Silverado Classic
2003-2007 GMC Sierra Classic
Document ID# 1871435
2004 Chevrolet Chevy K Silverado - 4WD This PI is being updated to add 2007 models. Please discard PIT3067B.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1871435&psdid=437&evc=sm#ss1-1871435">
Condition/Concern:
Owners may comment on a tinny rattle type noise from the roof at highway speeds. This noise normally occurs if the vehicle is equipped with a "Topper/Cap/Camper Shell" that is higher than the roof line of the truck or when towing a trailer.
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1871435&psdid=437&evc=sm#ss2-1871435">
Recommendation/Instructions:
To correct this concern, use an expandable (minimal expansion, such as, 3M 04320, Kent P10630 or equivalent) foam between the roof cross bow and roof sheet metal. Then install four 10" x 10" sound dampener pads to the under side of the roof sheet metal.
One supplier of sound dampener pads is Kent Automotive at 1-888-YES-KENT. Kent part number for 10" x 10" pads is P32947 or equivalent, quantity 10.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
999999994.gifWE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
My 05 did and my 07 NBS does it. The fix is ( for me each time) to put electrical tape down the two sides of the windshield where it meets the seal, and keep it there. The tape is black, just like the seal and the ends of the windshield.... so you can't even see it. I leave it there and have had no problems.
Any auto parts store usually carries it for about $3.
Go pull up the weatherstripping on the edges of your windshield, and you should be able to see what size/thickness of tape will fit under there.
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 1,009 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
