R-12 R134
Anyone know what year the US manufacturers switched from Freon to R-134? For OEM factory installed truck air conditioners.
Or was it gradual over a few years?
I had a '95 GM vehicle that still had R-12. So not sure if it was some models or what. When the compressor went out I had it changed over to 134. It leaked for a while but I had a big stash of R-12 cans that I "aquired" a long time ago for a whopping 0.49 each as the price tag on it says.
OK,Let me rephrase that...GM switched over the trucks in 1994 to R134. (My '93 K1500 had R12,My '94 K1500 & '94 S10 ZR2 had R134)
I think I remember that some cars,Mainly Geo's I think,still used R12.
I know my dad's '95 Lumina has R134 in it.
I can actually chime in on this one. Where I work I had to take an A/C class to work on the machines we will be producing in '09 and Federal law says mandatory switch over for ALL Vehicle Manufacturers is 1995. I guess if yours was an early '95 it could have the old system of R-12, but all from '95 on MUST be R-134a. Just my .02 worth.
Mine was an early '95 S-10. I know it was early because I bought it around October of '94. Friend bought a '95 later that year and his had the 134. His also had DRT's and mine didn't.
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 839 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
