Airbag Removal
I am planning on installing the steering wheel mounted radio controls on an '08 Sierra. Wanted to do a dry run on removing the airbag before ordering part #16824540 and part # 15819311. I have read previous posts and understand the process. The problem is actually removing the airbags. I know that you are supposed to insert a rod through two small holes on each side of the steering wheel column and release two springs. No problem so far. The problem is once I insert the pin into the holes, what am I feeling for? Am I suppose to just push straight in or pull something forward or back? How much pressure do you apply? Do I have to angle the tool in any direction? I have been fishing around inside the column for the past thirty minutes and can not get the springs to release. What I don't understand is what am I feeling for? Any tips from someone more experienced than myself?
Thanks,
Jim
TX
  • 10 months later...
Thanks,
Jim
TX
+1 I need the same help from someone!
You'll be fine and it should hook right up and work without problem. I forgot to reply to your PM, sorry. Make sure to disconnect the battery whil working on the wheel but you definitely DO NOT need to take your truck to the dealer for this. There are two holes in the shroud behind the cruise controls and where the radio controls will be. Use a small driver or coat hanger or something similar in those holes while pulling gently on the airbag to release the airbag retention clips. Once you have the airbag off, unhook the wiring harness for the airbag and the harness for the wheel. Next, remove the center nut and bang the wheel all around with the heel of your hand to loosen it and then pull. It should pop right off. Replace with the new wheel and work in reverse. Done!
I also did mine and it only took about 10 minutes. (I was adding a leather wheel) Push straight in the holes to release the airbag retainers. They are just spring loaded and don't require a lot of pressure. As noted above, make sure the battery is disconnected and I believe the wait time is 20 minutes for the airbag reserve power to drain. VERY IMPORTANT!
Otherwise, it was a piece of cake. Good luck guys.
DO NOT ORDER THOSE PARTS!!! That shroud is for a GMT800 and the switch is useless without the new harness. You will have to purchase a new wheel altogether. REPEAT: DO NOT ORDER THOSE PARTS!!!
I know because I have them in my garage.
    appletrav
    appletrav
  • Who's Online   4 Members, 0 Anonymous, 255 Guests (See full list)
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
