Heater Control Lighting
alz
I need part numbers for the bulbs that illuminate the heater control unit. They are the plug in type. The bulb has E9 on it.
99 GMC Suburban
Here's the VIN if it helps. Dealer said, needed last eight digits.
3GKFK16RXXG552180
Well, I broke down and went to the dealer. Part number is: 16203572. Hope it's the right part. Will post when parts come in.
Hope this helps someone.
I have a 2000 GMC Serria 1500, when I had it a the body show, alot of the parts were clasified deneli, so I don't know if the lamps will be the same. I have been gradually loosing heater control and radio control lamps, wondering if this is the same lamp? Thank in advance
I picked it up. Right bulb, but they have a yellow rubber coating over the bulb. Mine does'nt use the yellow on the bulb, so I'll just have to scrape it off.
Hope this thread helps someone out.
