What The!
Im stumped! I have a 2002 silverado 2500hd with the 8.1.The past few weeks,on 2 separate occasions,id be driving at a normal speed,then out of the blue,id lose all power for s spit second,in the same manner that occurs when you go over the speed limiter,and the fuel cuts out.But i dont think its that,it seems more like some sort of a short or something,and i do notice the battery light coming on in the message center when this happens.Has anyone experienced this before,or happen to know if theres a service bulliten on this? Any help is appreciated!
hey Tony, you posted in the LD section, you have an HD truck, but what I would check would be the Fuel System, Ignition System, as well as your onboard sensors to see if anything is loose, worn or damaged.
Ooooooops,can you tell im new to this forum!
no harm no foul, as long as you are behind the bowtie and not the blue oval or the red ram... :thumbs:
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 950 Guests (See full list)
