Transmission Filters
I searched around here but all I could find is "to flush or drop the pan" results(or to flush or not to flush :P ). I will definitely replace the filter, but I wanted a general consensus on what brand did you go with and why. Or..just chime in on the pros and cons of a filter. So far I am leaning towards AcDelco or WIX based on quality and reputatuion of their products. I will NOT use FRAM for the same reasons.
Thanks for the input.
John,
There are a very few suppliers of Trans filters on the market. By far, SPX Filtran is the largest of the group and supply them to us (CARQUEST) and just about every other company out there. The biggest difference in filter kits is the gasket. ATP, Wix, NAPA, CARQUEST all choose what gasket they want to supply with the filter. We have been using a cork/rubber combo for some time that was an excellent gasket. You can crunch it into a ball in your hand and it will not crack. We have recently moved to a rubber design by FelPro. It is supposed to be the latest technology and the best out there. It will not shrink or spread out from under the pan as some of the less expensive rubber gaskets. It also has bolt holes which are slightly smaller than the bolts. This serves 2 functions. The smaller holes hold the bolts in place while you are putting the pan back up and the bolts hold the gasket in place as well.
You will not see them sold in many place under the name Filtran. They provide OEs and companies such as us under private name brands.
Here is a link to them. Filtran
Hope this helps you with your decision.
Thanks Trey,
The gasket was also a factor in my purchase. I do hate the cork ones ,due to the usual tearing and cracking. I also appreciate the "inside scoop" that you provide on suppliers,great info.
I usually purchase parts and what nots from Carquest for both :P . They provide quality products vs the other stores. Granted you gonna pay a tad more, but you get what you pay for.
...Now for the guys in the CP store, not too knowledgable, but its been quite a while since I been there.
Do you have the 60E tranny? I would suggest doing a N/A Corvette C5 transmission pan and filter (24208593 pan kit, 24208574 filter kit,...GM part numbers). This pan has a great sump configuration where you will never run the pump dry from sloshing the fluid around like when launching at a drag strip or off-roading in 4x4. The entire set-up will run you about $140.00 for everything and is a great inexpensive upgrade for when you change your fluid and filter. It adds like and extra qt. of fluid as well.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
