4wd Issue On 2003 Silverado - Experts, Please Help
:wtf: I am on my last issue with my truck (thought I had them all) until I tested my 4wd .... it feels like the truck is working against itself when I switch it to 4wd-hi (haven't even tried 4wd-lo yet).
Checked the level in front diff, and is full. I have not used it in what seems forever, but know it doesn't feel right.
Anything I can do to make sure what my problem is or even better, get it fixed ??
change the fluid if you have not already done so, hopefully it wont be full of metal shavings.
Fluid does not have very much metal shavings at all ..... I let another truck mechanic take it around the parking lot today in 4wd and he thinks it is a bad pinion bearing.
How does a person know which front differential he/she has, and the specs for it, should I want to start looking for rebuilts or aftermarket replacement ?
    appletrav
    appletrav
  • Who's Online   5 Members, 0 Anonymous, 353 Guests (See full list)
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
