Tbyrne Motorsports Sales Thread
This thread will be updated with current specials so there aren't multiple threads cluttering the board. Please check back often. There is always something new going on! :lol:
One thing that we are trying is allowing you to make your own packages. Please let us know the year and model of your vehicle along with the brands that you'd like to go with. We'll provide a very discounted price for that group of products. The quote will be good for 2 weeks unless we know that a manufacturer will be having a price increase sooner than that. For example, maybe you would like to purchase an aFe induction, Corsa exhaust and a Predator programmer. Let us know that and the vehicle that they will be used for and we'll provide a quote.
That info can be posted here, you can send an e-mail to [email protected] or give us a call at 1-877-4-TBYRNE (1-877-482-9763)
We're going to run this offer through the end of December to see how it works.
Have a good day!
TBYRNE MOTORSPORTS LLC
ORDER LINE - 1-877-4-TBYRNE
E-MAIL - [email protected]
CHECK OUR WEBSITE FOR OUR EVERYDAY LOW PRICE POLICY!
What is the Diablosport Predator?
The Predator is a state-of-the art, high performance tuning flash programmer in a sleek handheld design. Once connected to the vehicle, the Predators internal computer recognizes the vehicles PCM and automatically picks the proper tuning files designed specifically for that PCM. Inside the Predator's memory are the actual tuning files that optimize spark timing and air/fuel ratio curves. The transmission parameters are remapped to improve the shift characteristics such as shift firmness and shift points. Unlike other 'tuners', DiabloSport's programming is performed in very small increments throughout the entire RPM range, for a smoother, wider and a more predictable power delivery. DiabloSport engineers spend many hours on the dyno, street and track to ensure the tunes provided with the Predator are the best they can be.
You have a few options when you order from us. They are -
Predator Handheld Programmer with ground shipping shipping
or
Predator Handheld Programmer with overnight shipping
(Shipping for locations in the 48 states. There is an additional charge for other locations)
And then you can add one of the connection cable packages if you like -
U7777 Serial port connection cable and power supply
U7778 USB port connection cable and power supply
One of those packages are necessary equipment if you want to update your DiabloSport Predator from the internet. They include a cable to connect the programmer to your PC and a 12 V DC power supply.
Pricing is lower than we are allowed to advertise so we have to ask that you give us a call at 1-877-482-9763 or e-mail [email protected] to receive a quote. Many have said that we have the best price that they have seen!
Have a good day!
CHECK OUR WEBSITE FOR WEEKLY SPECIALS! INSTALLATION SPECIALS AVAILABLE!
Truck Kit Features:
Big Brake Truck Front Hat Kits are engineered for use in conjunction with OE front hubs on a variety of competition, show, custom, and sport driving applications. Forged TC 6 piston calipers, Wilwood brake pads, machined aluminum hats, and 16" GT directional vane rotors exemplify award winning style and provide the ultimate in Big Brake Truck stopping power. Born from Wilwood's 25 year tradition of building championship brake systems, TC Big Brake kits are the perfect compliment to wheel, tire, and suspension equipment upgrades.
Forged Billet TC 6 Piston Calipers - Calipers Available in Black or Red:
Superior strength forged billet calipers resist deflection under load without adding unnecessary weight. Six stainless steel pistons generate high clamping force and balanced pad loading while resisting corrosion and reducing heat transfer from the pads. Standard kits include black calipers with the Wilwood signature. Red calipers available on custom orders.
Staggered Vane Directional Rotors
Staggered direction vane rotors offer the highest cooling efficiency by maximizing the surface area and air circulation between the rotor faces. SRP series rotors are drilled and slotted, and then finished in a silver zinc wash to enhance pad performance and give that high tech, corrosion resistant look inside the wheels. GT series rotors are face slotted to enhance pad performance and carry the maximum rotor mass for thermal stability in high temperature or competition applications.
Forged Aluminum Rotor Hats
High strength forged aluminum hats are rib reinforced to carry extreme loads and eliminate unnecessary, power robbing rotational weight. Black anodizing prevents oxidation while adding to the custom look inside the wheel.
Wilwood Brake Pads
Advanced formula high friction compounds have quick response, big stopping power, and extended fade resistance over OE compound pads. Low dust, low noise formulas are easy on the driver and the wheels.
Mount Brackets and Hardware
Race proven radial caliper mount system with brackets and premium grade studs, nuts, bolts, washers, and alignment shims assure an accurate and secure installation.
Plumbing
Fittings and hoses for most kits must be ordered separately. Hose kit part numbers can be found next to each kit in the ordering information.
TBYRNE Motorsports carries the complete line of Wilwood Brake products and we're offering deep discounts for all of they packages. Cars, trucks... it doesn't matter! Pricing is lower than we are allowed to advertise but you can give us a call at 1-877-482-9763 or e-mail [email protected] to receive a quote.
Part numbers and info can be seen on our website. Packages that aren't on our site yet can be seen on Wilwood's website.. Please let us know what kind of vehicle you would like to put these on when you contact us. Part numbers are helpful too! :lol:
Have a good day!
TBYRNE Motorsports brake upgrades from Baer, Wilwood, SSBC and Powerslot. Alot of the Baer and Wilwood packages require you to at least be using 18" wheels. Most of the SSBC brakes will fit inside the stock wheels. We've noted those and some that require larger wheels below -
SSBC
Front and Rear Short Stop... Slotted Rotor Upgrade Kit (does all 4 wheels)
Rotor Specs:
Diameter Stock
Thickness Stock
Venting Uni-directional (straight vane)
Standard Finish Slotted and Plated
Optional Finishes None
Kit Features:
4 wheel kit.
Includes high performance pads.
Includes Turbo slotted rotors with Xtra Life plating.
Front Quick Change Aluminum Caliper Upgrade Kit
A 3-piston caliper with either 38mm, 45mm or 51mm stainless steel pistons (size depends on application):
Tri-Power with 38mm or 45mm pistons for most car and light duty truck applications
Tri-Power HD with 51mm pistons for 3/4 and 1 ton truck/SUV applications
Constructed of aircraft quality aluminum
Lightweight aluminum reduces “unsprung weight” for better ride quality
Corrosion-free stainless steel pistons minimize heat transfer to the brake fluid for optimum performance
Comes standard with a clear anodized finish; optional powder-coating or polishing available
DOT design with dust seals
Available in Quick Change Aluminum Caliper Replacement Kits for a variety of vehicles
Currently available for Corvettes, GM Midsize and Fullsize cars, Late Model Camaro/Firebird, Late Model Mustang and Trucks
Direct bolt-on Force 10 Tri-Power HD 3-piston aluminum calipers and high performance pads. Bolts to stock spindles. Fits in stock wheels. Increases brake torque up to 16%.
Caliper Specs:
Name Force 10 Tri-Power HD
Number of Pistons 3
Piston Size 51mm
Constructed From Aluminum
Standard Finish Clear Anodized
Optional Finishes Polished or Powder Coated
Kit Features:
All hardware included.
Calipers come with clear anodized finish. Optional polishing or powder-coating available.
Includes Force 10 Tri-Power HD 3-Piston aluminum calipers.
Reuses stock cradle brackets.
*NOTE: Must be used with stock size rotors.
To order your calipers with optional powder coating, add the appropriate suffix to the kit number when ordering. (For example: kit A100 with blue powder coated calipers would be A100BU; kit A100-1 with red powder coated calipers would be A100-1R.)
Some new products from SSBC are -
Front Force 10 6-Piston Aluminum Caliper Disc Brake Kit
Disc to disc upgrade kit with Force 10 V6 6-piston aluminum calipers and 15" rotors. Bolts to stock spindles. Requires 20" or larger wheels. Increases brake torque up to 130%. Will not fit HD (8 lug) vehicles. Will only fit vehicles originally equipped with rear disc brakes - will not fit if it had rear drum brakes
Caliper Specs:
Name Force 10 V6
Number of Pistons 6
Piston Size 40mm
Rotor Specs:
Diameter 15"
Thickness 1.250"
Venting Directional (curved vane)
Kit Features:
Includes braided stainless flex lines.
Includes Force 10 V6 6-Piston aluminum calipers.
NEW FOR 2007+ TRUCKS AND SUVS (NBS) -
This will also fit some of the earlier models.
Front Force 10 3-Piston Aluminum Caliper Disc Brake Kit
Disc to disc upgrade kit with Force 10 Tri-Power 3-piston aluminum calipers and new stock size rotors. Bolts to stock spindles. Fits in stock wheels. Increases brake torque up to 17%.
Caliper Specs:
Number of Pistons 3
Piston Size 45mm
Rotor Specs:
Diameter Stock
Thickness Stock
Bolt Pattern 6 x 5.5"
Kit Features:
Includes everything in front Quick Change kit A187-5 plus new stock size rotors.
Includes Force 10 Tri-Power 3-Piston aluminum calipers.
Current sale pricing is lower than we are allowed to advertise. Please e-mail [email protected] to receive a quote. Please let her know what kind of vehicle you have and what package you are interested in.
Silver 112 version of the Magnuson supercharger -
with the complete Dynatech long tube header package -
for only $5729.99!
The 5.3 headers are pictured but we can take care of 6.0 owners too.
Want us to install everything? $995. would take care of the labor!
Offer doesn't apply to new body style trucks/SUVs yet.
There are alot of induction options available for the New Body Style (NBS) trucks and SUVs -
DUB
Volant
Outlaw
Airaid
K+N
VaraRam
We have discounts available for all of the brands available! Please give us a call at 1-877-4-TBYRNE or e-mail [email protected] to receive a quote.
Have a good day!
We have discounts available for the complete line of Vortech superchargers. If they make it, we sell it! Pricing is lower than we are allowed to advertise but we can provide you with a quote over the phone (1-877-482-9763) or if you send an e-mail over to [email protected].
Installation can be done here if you don't want to do the wrenching yourself.
But it gets even better, Vortech is offering a $250.00 mail in rebate for kits that are ordered by December 31st. To qualify, the purchase must be made by December 31 2007. To receive your rebate, simply send Vortech the rebate form, a copy of your purchase receipt, and your completed supercharger warranty registration form. More details for this can be seen at - http://www.vortecheng.com/pdf/VortechRebate.pdf
Have a good day!
We carry the full line of Borla exhausts and have discounts available for all of the systems that they produce. Pricing is lower than we are allowed to advertise so we have to ask that you give us a call or e-mail [email protected] to receive a quote. Please include the part number that your interested in when you contact us. That info can be seen on our website. Systems that we don't list can be seen at www.borla.com
Orders can be placed online or by calling 1-877-4-TBYRNE (1-877-482-9763).
Have a good day!
TBYRNE Motorsports sells and installs the complete line of STS Turbos! If they make it, we can get it and provide you with some amazing prices! Regular retail is listed on our website but the sale prices are much better! You can receive a quote by giving us a call at 1-877-482-9763 or by sending an e-mail to [email protected]. I doubt you'll find a lower price for one of these!
Have a great day!
DiabloSport will be having a price increase on January 1st so our current discounted price for the Predator programmer won't be around much longer!
We have a large year end order going in with Hotchkis on Wednesday December 26th so we're offering extra discounts for any of their products that are ordered by the end of that business day. In stock items will ship right away while others will go on that order and ship as soon as they arrive. Products are listed in the Suspension sections of our website along with the Hotchkis website - Hotchkis Sport Suspension. This applies to swaybars, leaf springs, coil springs plus much more! If Hotchkis produces it, then it's covered in this sale!
Pricing is lower than they would like to see us advertise but you you can obtain a quote by giving us a call at 1-877-482-9763 or sending an e-mail to [email protected].
Have a good day!
We carry the complete line of B&B TriFlo exhausts and have discounts available for every system that they produce. Pricing is lower than they would like to see us advertise so we have to ask that you give us a call at 1-877-482-9763 or e-mail [email protected] to receive a quote. Please let us know the year/model of your vehicle and the part # of the exhaust that your interested in if you have it. Info can be seen in the Exhaust sections of our website and also on the B&B site - http://www.bbexhaust.com .
Have a good day!
Oh yeah, you guys can reply and ask questions in this thread if you like :lol:
in respect, I can't figure out how to unsubscribe. I can't do it under "manage subscriptions"
if someone could elighten me, then delete this post.
