Opinions And Advice
hbr
07 Yukon - I'm thinking about swapping my head unit for a GM unit with NAV, DVD...etc.
I have a DVD player with a rear screen now, I would like for the front seat passenger to watch the same movie as the rear passengers.
My A pillar speakers say BOSE so I am guessing I have the BOSE system and the new unit would be plug and play?
Looking for info from anyone with experience or has done this swap. TIA
The overall swap would be pretty easy...I am assuming that you have an AM/FM/XM Radio now with the Single CD and the DVD Slot Up Top.....all you'll really need to do is get a DVD Compatible Nav Unit from somewhere....the best way to confirm if they are DVD Compatible is to look at the unit and there will be a DVD logo to the bottom left of the screen in white print on the faceplate of the Radio.
If your current setup says BOSE on the A-Pillar Tweeters then yes you have the Bose System.
Radio should be plug and play but you will want to get ahold of Jason at jpcustoms.com and order up that VSS Wiring Harness so your Navigation would be correct. Its Easy to install. Also you may want to hook up the Voice Recognition part of the Radio which is two wires that need to be connected between the radio and one of the OnStar boxes...this makes it so you can utilize full function of the radio, just like you would if it came equipped from the factory.
If you want do a search on here...you can learn alot about how to take the old radio out and put the new one back in, also wiring, etc.
Let me know if you have any questions.
Travis- thanks for the info. I'll run a search on the remove and install. I'm pretty sure I'm going with a new GM NAV unit. I appreciate the offer, I'll PM if I run into any questions. Thanks bunches.
    liddlera
    liddlera
  • Who's Online   2 Members, 0 Anonymous, 715 Guests (See full list)
