Remote Start/hvac Controls
I recently purchased a 2008 extended cab 4x4 LT1 silverado. So far I love the truck. Once question though, the owners manual states the HVAC controls have default settings when using the remote start depending on the outside temp. The last several mornings it has been 25-30 degrees and when I used the remote start nothing comes on in the truck. Is there something I am doing wrong?
Thanks for the help
Mark
If your talking about the heat coming on after remote starting it... it will not start blowing till its warm
Yep, you have to give it a few minutes before you get in...especially with it being 25 degrees out.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
