How Do You Change The Day Time Running Light Bulb?
take out the headlight, turn the DRL bulb in the light left, slowly pull out, then pull the bulb out. Make sure the bulb is a 4114
I would replace the drls with 3157NALL, they are amber long lifes. If you look at your drl bulb socket you will notice its burnt looking...thats due to the clear bulbs getting too hot, the ambers wont do this.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
