Chains On Gmt900 4x4 Pickup?
When I bought my truck they made me sign a waiver that said that I wouldn't use metal snow chains, and if I did any damaged caused by chains wouldn't be covered. They said something about approved chains. Does anyone know about this? Where I live chains are sometimes legally required (4x4's have to HAVE them, if not use them).
If its ever really hairy I'll take the K5 so I doubt I'll ever actually need to put them on. I just figure if I have to have them by law they might as well fit, just in case.
This is the only thing it says in the owners manual....
Document ID# 1729544
2007 Chevrolet Silverado - 4WD
Tire Chains
Caution: If your vehicle has dual wheels or P265/65R18, P275/55R20 or LT265/70R17 size tires, do not use tire chains. They can damage your vehicle because there is not enough clearance. Tire chains used on a vehicle without the proper amount of clearance can cause damage to the brakes, suspension, or other vehicle parts. The area damaged by the tire chains could cause you to lose control of your vehicle and you or others may be injured in a crash. Use another type of traction device only if its manufacturer recommends it for use on your vehicle and tire size combination and road conditions. Follow that manufacturer's instructions. To help avoid damage to your vehicle, drive slowly, readjust, or remove the device if it is contacting your vehicle, and do not spin your vehicle's wheels. If you do find traction devices that will fit, install them on the rear tires.
Notice: If your vehicle does not have dual wheels and has a tire size other than P265/65R18, P275/55R20 or LT265/70R17, use tire chains only where legal and only when you must. Use chains that are the proper size for your tires. Install them on the tires of the rear axle. Do not use chains on the tires of the front axle. Tighten them as tightly as possible with the ends securely fastened. Drive slowly and follow the chain manufacturer's instructions. If you can hear the chains contacting your vehicle, stop and retighten them. If the contact continues, slow down until it stops. Driving too fast or spinning the wheels with chains on will damage your vehicle.
Well there you have it from the General, not the dealer who has no say in the warranty and knows far less about your vehicle then GM.
Iam not a lawyer but i think the dealers waiver is good toilet paper.
    mighty K20
    mighty K20
  • Who's Online   1 Member, 0 Anonymous, 535 Guests (See full list)
