305/55/r20 On 20x10's And -21mm Offset
Will these fit stock suspension on a Z71, or will I have to put a 285/55/R20 on it? Anyone with a 20" x 10" wheel knowledge and input is VERY helpful! I know 285's fit under the stick suspension, but I have no idea if the 10" wide wheel will cause a problem.
they will rub, i have 305/50/20 kmc rockstar wheels they are 20x10 24mm offset and i have a 2'' leveling kit and still rub a little on hard turns so probably will and i have a nbs truck 4x4.
I like how they look, but maybe if i put 285's on there they won't rub. Maybe someone can chime in that has 285' son 20x10's.
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 713 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
