Steering Stabilizer
Guest Riggs
alright (truck specs in signature) but i have 33x12.5x15lt tires
they pull in many cracks in the road and usually always fighting it, (lot of country roads out here). sometimes i cant even control the truck it pulls so much in a direction. i just had it aligned about 3 weeks ago.
so i was wondering about a steering stabilizer.
what is a good brand to get that isnt very expensive? im not offroading im usually just driving to school or work.
i only need a single, unless you think i need a double. i plan on getting 35x13.5x15 toyo open country's within the next 3-6months.
thanks.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,194 Guests (See full list)
