L43 Head
luis93436
2001 sonoma 2.2 L43
Hello today is sunday and the dealer is close I hope some one can help me:
while swaping an engine I noticed that there are two different types of heads for the 2.2 liter sonoma.Both engines look the same but I notice the gasket for the exhaust manifold is not the same, then I look at the head just to see some differences between the two,( I never bother to check when I bought this used one) one is the flex other the regular (i think) I was going to only swap the exhaust manifold by I am afraid is not going to work should I change the head to? are the blocks the same? any ideas?
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,105 Guests (See full list)
