08' Radio Removal?
Carefully pry off the surround trim, using your fingers. Remove the two screws that hold the temperature control. Then remove the four screws that hold the radio. I've attached instructions for the factory XM install. Third page covers removal of the radio, but it shows the LT setup. The SLE setup is as I've described.
XM_Install.pdf
XM_Install.pdf
XM_Install.pdf
XM_Install.pdf
if you have the 'truck' interior ... only real difference is when you are putting the trim peice back on .. you have to twist it a bit to snap it in place (less you remove the top part from above the inst cluster and such then it just snaps in place)
