Gmc Lift Kits
Aloha!
First post on this forum, and I'd like to say hello from Hawaii! :)
I have a 2002 Yukon SLE 4WD. I'm looking for a good 4-6" suspension lift for it and looking to run 33" or 305/70 tires (I don't want it skyed). I've been looking through Fabtech, Rize...etc but what I don't want is the front wheel push out (bout 3") you get when you change the spindles/knuckles. A kit that doesn't require welding would be great also.
Does anyone have any suggestions or have experience using a lift that might be along the lines of what I'm looking for? Any suggestions would be appreciated, even if it's a point in the right direction.
Thanks!
Welcome. Procomp and Rancho are a couple. You want a fulldrop kit if you don't want the front wheels sticking out. Fulldrop means it drops the transfer case the full amount. You don't use after market knuckles.
Thanks gray. I may have to end up welding after all. The pro comp looks like a good kit, but requires welding the way it looks. I was just looking at the lift being reversible if I wanted to lower it back down.
Thanks again!
