Steering Wheel Alignment
scottmoyer
A few months back, I needed to replace the factory tires. I had multiple issues with the shop and the tires I had put on the truck. I had the shop do an alignment when they put the tires on and the tech stated that he was going to adjust the steering because there was sp much slop in it. Not knowing what this really meant, I said ok but I was perplexed why I would have so much "play" in a 2006 truck with 35k miles. While driving home, I almost put the truck in the woods because the steering was so tight that any movement of the wheel made the truck swerve. I took the truck back and asked them to add the play back in the wheel that it was dangerous in it's current setup. Since then, my steering wheel sits at 11:30 while going straight. I requested an alignment 3x at another shop that acknowledges the tire warranty. The truck tracks straight, but the wheel is still off. I don't want to go back to the shop that did the work initially since they damaged all 4 rims and did $2200 damage to my wifes car. What did they do that another shop doesn't want to mess with? Why is my wheel offset, but the truck goes straight? How can I get this fixed? Thanks
Not sure specifically on your truck. The two items seem unrelated. The play adjustment in the steering box is very temperamental and I played with that once on a car and can appreciate what you went through trying to steer that thing with the adjustment too tight. Take baby steps on that adjustment.
If the truck tracks straight but has the unnerving wheel tilt, any good alignment man can adjust that without screwing up your straight tracking. He would center your steering wheel and then adjust the tie rods to turn the wheels to the left until they track straight also.
Steering wheel can be way off and the truck be aligned perfectly. The tech apparently didn't have it centered when he adjusted the front end. Other than being annoying the wheel is not an indicator of the alignment. It's a pretty easy fix.
They should not have tinkered with the "play" on an 06 35K truck... what do these do... work on 65 Chevies all day?
    tararebecca
    tararebecca
  • Who's Online   2 Members, 0 Anonymous, 484 Guests (See full list)
    • I agree, simplicity and reliability matter more as vehicles get more complicated. A V8 work truck option with fewer electronic features and a stronger warranty would definitely appeal to a lot of buyers who use their trucks for real work. Customizing it with trusted outfitters is often the best way to get exactly what you need
    • I’ve heard similar complaints from newer vehicles where the factory “premium” systems don’t always live up to expectations. A good installer should be able to improve the sound without turning it into a bass-heavy setup. I’d look into upgrading the front speakers, adding a quality DSP amplifier, and possibly improving sound deadening first—those changes usually make a much bigger difference than just adding a subwoofer. Hopefully someone local can recommend a reputable installer in the Las Vegas/St. George area.
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
